N983LK
RV-8
Trimming and sanding the windscreen upper fairing
Sanded micro on RH elevator. Applied another coat.
Used a handheld mini belt sander to sand/taper the upper windscreen fairing laminate. Finished trimming the aft end of the laminate.
Sanding the windscreen fairing laminate
Getting closer to the final shape
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
