N983LK
RV-8
RH HS tip closeout
Sanded the LH HS and elevator tips. The gap between them is now 3/16" which is within spec.
Trimmed 1/8" off of the aft end of the RH HS tip. Cut a new plywood closeout and floxed it in place.
Sanded the tip of the RH HS
LH HS and Elevator tips after sanding
RH HS tip with replacement plywood floxed in place
RH elevator tip ready for micro
RV-8 Home
4531
428
Baffles
43
189
276
Cowl
285
418
199
Flight Testing
1522
Prep for flight
Shop Setup
958
