Brief Description: Fwd baggage door hinge support closeout angle
Fabricated an angle to rivet on to the bottom of the baggage door hinge support to cover the exposed edge of the closed cell foam inside the support. This was mainly done for asthetics because I didn't like the look of the foam.
Matched drilled the hinge support to the angle.
Primed, painted and baked the angle and riveted it in place.
I still have to do something to the foam that can still be seen near the hinge. Possiibly caulk or epoxy/micro
