Drilled out rivets in the forward top skin adjacent to where the forward baggage door was slightly above the skin.
Cut thin shims to fit between the fuselage forward top skin and the firewall (near the top forward corner of the baggage door) and the avionics bay bulkhead (near the lower aft corner). Inserted them in place and match drilled through the skin. Removed the shims, deburred and dimpled them and reinserted them. Re-riveted the locations where the rivets were drilled out with the shims in place. The fit of the door is better.
Scuffed, cleaned and primed the IML of the baggage door.
Reinstalled the rudder pedals and forward baggage side panel.
