Mikes Web Site
Date:  9-6-2015
Number of Hours:  1.50
Manual Reference:  8-20
I worked on the outer seal support for the sub panel. My bandsaw needs a blade and the Dremel is broken. I had to make the supports mostly by hand. I set the radius of the cutouts with the drill press. Then I cut the openings with shears and cleaned them up with the small file. Very tedious. I have not used the shears much at all in the entire project ,as I prefer the band saw.
