Mikes Web Site
Date:  1-2-2015
Number of Hours:  5.00
Brief Description:  J- channels, Manual trim cable
I had to re do the upper J-channels that go beneath the aft top skin. I had mis-drilled these earlier in the build. Next I installed the manual trim cable. Something was not right at the cable mounting to the tab. I finally realized that the trim tab (which was purchased from another builder) was set up for electric trim. So, I had to remove the trim tab horns and install new ones.
