Mikes Web Site
Date:  7-21-2013
Number of Hours:  1.50
Manual Reference:  8-4 dwg 18
Brief Description:  longerons
Before I left on vacation I had started on the right longeron. I had the shallow bend done and was drilling the F-721. There are 2 holes at the foward end and after I had drilled one hole I clecoed in the wrong one. Since I had not noticed the entire piece was drilled wrong. I thought the longeron was junk, but some builder friends say I can fix it. I will make the repair later. Tonight I did all of the bending on the left longeron and put it away. I also trimmed the upper J channels.
