I had to clean out the shop. I have seeing alot of mouse droppings. My wings have been in storage for a long time and I had to make sure there was no damage. I only worked on the plane in ernest for half an hour. I installed one of the jack points from www.motorsports.com. This makes it so that you raise the wheel with a lightweight car jack.
This piece is bolted to the gear
This is the jack point which is carried in the aircraft and added when needed.
