More cutting and fittiing of the cowl. This thing moves around quite a bit. The fit is mostly good, but one of the issues is that the upper hinge uses a smaller pin. This leaves a lot of slop. Most of the hinge around the firewall perimeter has been drilled.I just need to fit the left side , then I can install the side hinges.
I have a gap here but I will deal with it later after the side hinges are installed
