I spent about an hour on the empanage fairing. Frustration took over so I went back to work on the sub panel. I received some parts from Vans for the fire wall and a new center rib for subpanel. I had drilled the old rib in the wrong sequence which led to it not lining up. The rivet line along the lenth of rib is not as centered as I would like, but it was the best I could do because of the way the end of the rib fits the sub panel. I also fit and drilled the forward canopy decks.
