Several small projects over the last few days. I pulled the the canopy to make it easy to install avionics. While I had it off I made some repairs to the front edge. It had snagged several times, so I straightened it as best I could and then added a strip of fiberglass for strength. I have been sanding and sealing the bottom cowl. Lots of sanding and filling left to do.The MAP sensor has been mounted. Started to mount the com antenna. Pictures coming soon.
