JAKE'S WEB SITE
Date:  4-12-2017
Brief Description:  Drain slots
Jeff this is an FYI. I went back to Jake's today and drilled out drain holes in the trailing edge. There were supposed to be drain slots beside the ribs. There was no slot, and the area involved was filled with the old adhesive. Jake and I drilled drain holes in the trailing edge and checked each hole to make sure that they would drain. We are now the Proud Owners of 9 new Drain Holes! By the way, the work we did looked good and made the trailing edge very solid.
Thanks for your help. John Ringer
