6" Tail Wheel and Tail Skid Instaltion copleted per plans. The Push Rod as deliverd wuld not initially fit. As per Sonex Technical Assistence I was advised to make a bend in it to make it ft.
It needed a bend in two places to make it fit by using a 2X4 with a hole and applying some brute strenght. I bent up about 10 deg. 3 inches from the top and down about 10 deg. 3 inches from the bottom. These bends allowed the two ends to be parallel.
