JAKE'S WEB SITE
Date:  10-18-2016
Number of Hours:  4.00
Manual Reference:  WIX-CO1
Brief Description:  Ruddervator Control Rod and Mixer Installation
To be able to install the Mixer and Ruddervator Control Rod I placed the Aft Fuselage on the 4 ft. saw horses so I could get under it and work through the open bottom.
Bob a I drilled a hole in the undrilled end of the Push Rod to match the location from the end of the rod like that of the drilled end. This later turned out to be incorrect and we had to relocate the hole. After the fact I found the instructions on page WIX-C01 that we should have followed.More time was spent researching and finding the right directions. then removing anf replacing the Push Rod than to actually do the work.
