Bob and I went through the plans and made some selections of additional hardware we needed for the current sections we are working on.
The amount pf Phenolic Sheet on the hardware list seemed to be excessive so we made a review and guess at the proper amount. This material is very expensive and I wanted to not order more than needed. I hope we are right!
Also today Bob and I positioned and clamped the Upper Attach Angle and drilled out the four 3/16 hole through it alligned with the holes in the Tail Post which were already drilled. I had saved this step until I had fit the Tail Assembly onto the aircraft making sure it would fit within the upper and lower Longerons. I feel like this was a better fit than just using the plan measurements.
