No problem with this except bending without kinking the tube was a challenge. I did not install an oil separator. I am glade that I only teporarily installed originally. Because the bend location is directly affected by the Oil Cooler location.
I also attached a rubber hose section to easily bend down to attach to a straight aluminum tub termining just past the bootm cowl through the bottom exhaust tunnel.
