Installed one gasket over studs on the oil sump opening and then installed the oil screen. A second gasket is installed over the studs over the oil screen and then the oil sump plate. 6 mm copper washers and 6 mm nuts are installed but not over-tightened.
Use 60 lb-inch as thr torquehe 6 stud nuts. No sequence is required but I criss crossed just becaue I wanted to. The studs do not all go through the nuts but that is OK.
Next installed the copper washer and oil drain plug.
With each oil change these steps will need to be repeted.
