JAKE'S WEB SITE
Date:  2-24-2018
Number of Hours:  40.00
Brief Description:  Panel
My main panel includes an MGL IEFIS Lite which class panel displays flight instruments, engine monitoring displays and radio and transpnder controls. It is a touch screen or button controlled and includes synthetic vision. The IEFIS includes maps and supports navigation because it is paired with a SP6 magnetic compass.The engine monitoring is controled through a MGL RDAC controller monted on the firewall.
An MGL V6 Radio has a head comtroller on the panel providing a secondary method of operatopn.
The panel also includes a panel mounted Ipad and cooling mount with ForeFlight software to provide moving map, ADS-B weather and traffic. The mount has 4 small fans which cools the Ipad and is adjustible and can pivot any direction to deal with glare. The mount and the Ipad can plug into a USB port located behind the mount.
There is also an additional 2 port USB connecter located on the panel.
And of course all engine, avionics, and light switches are located up each side of the panel.
MGL RDAC engine monitor on firewall
