My hinge drilling tool is a take off from some I found on other builder's websites. I chose to use long run of stationary hinge thinking it may help to keep the hinge to be drilled straighter. I set it up to be able to be fastened to the drill press platform wiht countersunk plastic bolts and nuts. You can tighten by hand making it easy on and off as well as for lining up. Also this fastening method does not require clamps that tend to get in the way.
