RV-8A construction
RV8A
Wing Mounting
Fuselage all level.
Made spacer for rear spar under digital level as per plans.
Installed 2 plumb bobs on the leading edge of both wings to check sweep.
made temp wing bolts
rear wing spar drilled after wing is set.
RV8A Home
