KURT'S WEB SITE
Date:  3-3-2015
Number of Hours:  4.00
Manual Reference:  7-H-7
Brief Description:  Worked Upper Chanel for Steel Spring Gear
Located and installed upper bearing (7H7-4C, Nylon 6/6) int upper chanel (7H7-1SP). Located and drilled 9mm gear struts. Drilled ends of bungee pin (7H7-6C) for cotter pins. Bungee pin is now used to attach gear dtrut ends to the upper gear spring keeper. Trial fit of steel spring nose gear parts.
