Brief Description: Complete underside/trailing edge of port-inboard s
Un-strapped and mounted slat in jig topside down. Strapped in place with blocks to ensure curvature of slat while drilling & clecoing underside trailing edge (7S1-4). Drilled out to #40 every other hole (inside rivet line) then drilled to A4 (copper). Removed from jig, turned over and drilled #40 (final dimension for soft rivets at trailing edge) & clecoed (silver).
Underside of slat in jig adding trailing edge (7S1-4)
