Brief Description: Worked Upper Chanel for Steel Spring Gear
Located and installed upper bearing (7H7-4C, Nylon 6/6) int upper chanel (7H7-1SP). Located and drilled 9mm gear struts. Drilled ends of bungee pin (7H7-6C) for cotter pins. Bungee pin is now used to attach gear dtrut ends to the upper gear spring keeper. Trial fit of steel spring nose gear parts.
