Brief Description: More firewall/nose-gear parts layouts
Lots of parts attatch to the firewall and all seem to cross, overlay, or abutt so rivet locations must be checked and adjusted against the adjouning parts. Check & double-check locations. Clecoed channel doublers (7F7-8C) in place for the steel sprig arms pin. Drilled out pin holes (5/8" dia) through both 7F7-8C doublers and ther 7H7-2C channel. Locaed and scriber position for the steering arms pass-thru on either side of 7H7-2C. Prepared Rear (7F8-4) and Front (7F8-5) Lower Bearing plates. Nylon Lower Bearing (7H7-4C) will need to be split for mounting to the twp parts of the lower bearing plates so that the nose gear assembly can be removed.
