Brief Description: Remove clecos for RustOx & finish
Removed clecoes from underside. Applied RustOx to interior of slat structure and trailing edge. Deburred and re-strapped structure in jig and clecoed every other location (copper) and #30 (silver) at trailing edge. Removed straps and riveted top skin to structure. Cut 20mm notch from both ends of trailing edge to fafilitate installation of fibeglas tip and insertion into outboard slat at later time. Flipped to underside and riveted all A4 locations. Installed soft rivets in trailing edge.
