Karl's Web Site - HB-YNB
CH-7, Kompress Charlie
Gear
2-24-2008
Gearbox-oil-cooling 2
Oil-cooler installation, in front of water-oil cooler. Oil runs from gearbox lower forward fitting to the filter, from filter to pump-IN, from pump-OUT into cooler and then from cooler back to the gearbox, upper rear fitting.
Oil filter (above), below oil cooler
Main gearbox oil filter installation
Oil cooler
JODEL D 11 Home
CH-7, Kompress Charlie Home
572
Carburetor
Cyclic, Collective
Electric System
Fuel-System
Gear
Instruments
Main Rotor
Oil- Watercooling
Rotor blades
Tailboom
Test Flight Torino
Test Flights
Unpack/stow the kit,
W&B
www.kistleronline.ch
