Longitudinal / side trim The movable rod of servomotor has to line with nose up and down bar of cyclic. Before fixing make sure the movable servomotor rod is fully extended. Warning: do not power the trim motor only to extend the rod, rather turn it out manually until you hear the "click" from stop-switch! Side trim: good to drill hole for the bolt when still room available, before installation of battery, etc.
