The maximum airbox temperature should never be higher than 72 ° celsius, above this temperature the waste-gate of the turbine will open to bypass air. Since this would be dangerous during approach or take-off, I decided to install an intercooler to stay away from the 72 degrees. Everything worked fine from the beginning and was tested during a flight to Huefifirn, Vorab and Grap Sogn Gion
