Monitor Alternate air butterfly door Increase flap 10 position 2-3 degrees Remove and replace pitot static system with Lancair version Permanently mount fire extinguisher Isolate and better identify Gear handle Install backup gear indication lights Monitor remote oil filter and inspect fittings for leaks and security Crotch seat belt needs adjustment in relation to seat cushion to allow full aft stick deflection.
Seat pan under right thigh is making contact with controls needs additional clearance. Throttle controls need adjustment to make full power.
Flight testing is not concluded Trims needs to be secured to reduce non desirable movement. Leak check pitot/static system
De cowl and inspect for leaks, check security of fasteners and hardware
