Removed landing gear sequence valve assembly. Disassemble and installed new servo onto valve assembly. Reinstalled into aircraft. Tested, the interference seems to be gone with servo. Gear works properly going up. Still not working properly in the down position. Inner doors are not opening. Replaced all four landing gear microswitchs for the sequence system with improved ones from Lancair # 1XE1-T.
