Brief Description: assembled rudder bell crank assembly
assembled rudder bell crank assembly per chapter 17-25. Found rudder bell crank #4650 did not match drawing in Chapter 17-25. Spoke with Josh at Lancair. Dimensions seem to be correct. The only difference to the Bell crank it has to bumps that are presumed to be used as stops in the old design. Installed parts such that the bombs do not interfere with the operation of the bell crank.
