Brief Description: prepared and cut hole in right wing tip
prepared and cut hole in right wing tip for navigation light. Per legacy innovations instructions. Ran into a problem where if the opening was opened as big as the part the winglet would run into the light assembly. This was partly restricted by the navigation antenna. It was a frustrating day and I find that the parts from legacy innovations poorly fit. To correct the issue I cut out 3/8 of an inch out of the center of the wing light molding.
