Brief Description: measured flaps hinge placement.
Measured flaps hinge placement from right to left. Found that the right outside flap change is three quarters of an inch shorter compared to the right flap. The problem is the core length at the outside hinges for the flaps comparing right leaning to the left wing. It is found that the core length on the right-wing is shorter. Removed flaps and compared hinged arm mounting points. Found that the right outside hinge is not mounted as the same to left.
