Very Heavy winds, unsuitable for any testing of significance. Normal system and performance tests performed. Trim Shots attained within satisfactory time allotments.
Aircraft displays neutral stick stability due to stick friction. Recommend improved bearing surfaces throughout control system.
Winglets reduce roll rate by 20% and increase stick force in roll by 20%.
