Slowed down a bit by all this, but in the end weight will be saved by not painting interior or exterior. If aircraft is later to be stored outdoors, I will paint as needed then to preserve and prevent corrosion. Yes I will be painting or hot coating the steel parts.
Will update this and next page as progress will be ongoing for the duration....
Right side polished around outside of baggage area
