Days off spent adding 10 gussets inside rear fuselage, then ...
started adding diagonal L Angles also as in this 1st photo, most maybe half of builders seem to be doing this and will help prevent oil-canning on start-up at low rpm's and make for a more solid fuselage by adding these stiffeners without adding much weight...
