Manufactured GPS antenna support bracket. Manufactured oil breather hose support bracket. Match drilled and deburred both brackets to the firewall. Primed both brackets. Bled the brake system with MIL 5606H fluid. Ran GPS wiring from platform to GPS and bundled. Installed two wire bundle supports on the engine mount. Manufactured additional ground wire from grounding block to the starter.
