Installed terminal ring for A/P disconnect wire and installd on A/P terminal block. Wired all ground shields to intercom D25 connector and installed connector cover. Soldered connections to audio variable resistor. Installed intrument panel and place switches. Installed R tack leads to terminal block. Installed connectors to autopilot control panel audio cable and installed on ground block.
