Soldered shielded wire to tach input of electronic ignitionI. Connected electronic ignitionI tach output to blue/white Dynon R tach input. Installed power lead for ELT and tested OK. Wired starter switch to E-bus and to "S" terminal of starter solenoid. Installed starter warning indicator wiring to "I" terminal of starter solenoid with a 24 AWG fuse link. Installed light into panel. Installed rubber nipples on all starter wiring. Tested starter OK.
