Installed nutplates for POS-12 flap position sensor. Manufactured pushrod assembly for flap position sensor from 4-40 push rod and end clevises. Manufactured flap position arm to attach to flap actuator arm. Attached flp position arm to flap actuator tube and adjusted position for full travel on sensor. Installed connectors and Molex plug for flap position sensor. Added cable bracket at bottom side of bulkhead. Routed sensor wire with existing wire bundle.
