Installed switch guards for Aux Alt and E-Bus feed. Drilled additional switch hole in switch panel for trim power switch. Manufactured spacer for ground power switch. Installed battery side connector onto E-Bus slternate feed line and secured line to R side wire bundle. Installed autopilot circuit breaker. Labled remaining R side switch panel switches and CB's.
