Ran wiring for ADSB GPS antenna. Drilled fuselage and installed transponder antenna. Installed connector on transponder RG400 cable. Ran power and ground lines for ADSB and installed connector. Ran NAV/COMM antenna wire. Turned battery contactor and wiring around to right position.
