Match drilled forward avionics shelf to F-871-1 forward baggage side. Deburred, dimpled and countersunk. Arranged main bus, e-bus, diode and voltage rectifier on shelf. Drilled for nutplates on shelf and supports. Deburred all holes. Manufactured L&R wing cable clamp supports. Spaced and drilled all mounting holes for Dynon FlightDEK 180 rack. Deburred and edge finished. Prepped all parts for painting as well as wing root areas on fuselage.
