Installed Molex connector on pitch trim servo wire. Installed WDG clamps for servo and trim wiring. Installed ring terminal on ground cable. Rivet nutplates and braces for ground power receptacle. Fabricated the ground and hot leads for ground power receptacle. Installed ring terminal to forward ground cable. Drilled grounding block to 5/16" and attached to firewall back to back. Fabricated grounding strap and attached to ground block.
