Rivet F-8103 release assembly. Manufactured F-8103E lock pin. Manufactured F-8102A handle. Installed F-8103 release assembly on the WD-416 rudder slide. Manufactured F-8102B fairlead insert and installed into WD-818 rudder socket. Routed the free end of the F-8102 release cable through the fairlead and handle. Tied knot and cut cable. Bolted rudder pedal assembly to forward cockpit floor. Reversed bolts for rear rudder pedals due to interference with F-878 cabin braces. Attached front and rear rudder cables.
