Riveted AN490-HT6P pushrod end onto L & R pushrods. Final drilled #12 WD-817 and WD-818 rudder slide bar and support. Separated and edge finished all F-8103C release spacers. Match drilled #12 holes on sides of WD-818 rudder socket, removed and deburred. Drilled, deburred and riveted F-8107 collar in place. Match drilled #12 front and back side of F-874 rudder pedal side blocks into the WD-816 slide tube. Removed and deburred. Applied grease to tube assemblies, reinstalled and bolted F-874 side blocks in place. Painted front seat back, rear rudder pedal brackets and aft cockpit side panels grey. Primed rudder pedal release assembly parts.
