Brief Description: Mid Fuselage Skin and Structure
Painted rear throttle lever black. Deburred edges of both F-823-1 mid side skins. Rolled bottom aft corner of both mid side skings. Clecoed seat bottom support assembly to center section. Final drilled common holes between seat ramp supports and inboard seat ribs. Cut 2 5/8" hole in F-815-R1 forward outboard seat rib and R mid side skin for R cockpit air vent hose. Clecoed entire mid fuselage side skins and structure together.
