Karl Richcreek's RV8 Web Site
Date:  7-28-2010
Number of Hours:  5.50
Manual Reference:  8-12, OP-01
Brief Description:  Seat Rib Subassembly
Match drilled all common #30 holes in rear spar attach bulkhead.
Drilled and countersunk seat rib angles nutplate holes.
Manufactured both F-805D brackets.
Match drilled F-805D brackets to structure.
Assembled both seat belt anchors.
Final drilled all #30 holes on both forward L & R inboard seat rib assemblies.
Match drilled aileron trim support brackets to L & R inboard seat ribls.
Cut 1/8" slot on trim slide tube for servo attachment.
Enlarged snap bushing for slide tube.
