Karl Richcreek's RV8 Web Site
Date:  6-2-2015
Number of Hours:  6.00
Brief Description:  Elevator installation
Match drilled aft two holes of L&R inspection plates and fiberglass fairing.
Deburred, countersunk and tapped parts for #6 screws.
Installed S15 screws on canopy lock block.
Installed L&R elevators to HS.
Bolted elevator push rod to aft control bellcrank.
Formed trim tab stinless steel hinge pin and safety wired in place.
Put sleeve on trim tab wire.
Crimped connectors for trim tab power and position indicator wiring.
Tested trim tab to full travel in both directions.
