Installed L rear canopy rail screw with washer spacers for positive stop. Reinstalled all avionics into panel. Cut rear corners of windscreen to fit flush. Match drilled #30 L & R F-8104 forward skin support ribs into WD-814 windscreen support. Deburred all sides. Rivet forward skin supports to windscreen support. Drilled and deburred canopy rollers to canopy frame. Adjusted rear canopy bow for proper clearance. Cleaned all canopy spacers. Prepped canopy frame and glued spacers at 2 inch intervals on center. Prepped upper forward skin and glued spacers for windscreen.
